REFERENCES PIECES HONDA ( source ITRCA )
Faster_seb
Message par Faster_seb » lun. févr. 06, 2006 2:50 pm
5 premiers chiffres = numéro du part
3 suivants :
P73 = Integra Type R
PCT = Civic Type R
P72 = B18c
PR3/PW0/P30 = B16a
3 derniers :
A0 = USDM spec.
00 = JDM Spec
Block Internals
13010-P73-A00 Standard Bore Piston
13011-PR3-004 Standard Bore Ringset
13020-P73-A00 .25mm Oversized Piston
13021-PR3-004 .25mm Oversized Ringset
1310-P30-G00 Standard Bore Piston
13020-P30-G00 .25mm Oversized Piston
13021-PR3-003 .25mm Oversized Piston
13310-P73-J01 Crankshaft Assembly
13810-P73-J01 Crankshaft Dampener
90017-PR3-003 Crank Dampener Bolt
90704-634-000 Crank Key
13210-P73-000 Connecting Rod Assy
1332_-PR3-004 Upper Main Bearing
1334_-PR3-004 Lower Mainbearing
1321_-P72-003 Conn Rod Bearing
Cylinder Block
11000-P72-811 Bare Block Assembly
91214-P2F-A01 Rear Main Seal
11200-P72-010 Oil Pan
11251-P30-004 Oil Pan Gasket
11221-P72-000 Windage Tray
15650-P30-000 Dip Stick
11950-P73-J00 Engine Block Stiffener
Cylinder Head
12100-P73-J00 Cylinder Head Assembly
15810-P30-005 Vtec Solenoid
12251-P30-014 Headgasket(Vtec)
90006-P72-003 Head Bolt
12204-PR3-305 Intake Valve Guide
12205-PR3-305 Exhaust Valve Guide
12237-P30-000 Cam Rail
Head Components
14711-P73-J01 Intake Valve
14721-PR3-000 Exhaust Valve
14761-P73-J02 Outer In.Valve Spring
14751-P73-J02 Inner In.Valve Spring
14761-P72-003 Outer Ex.Valve Spring
14751-P72-003 Inner Ex.Valve Spring
12210-PZ1-003 Intake Valve Stem Seal
12211-PZ1-003 Exhaust Valve Stem Seal
14765-P30-000 Spring Retainer
14781-PR7-A01 Spring Keeper
14620-P30-000 Rocker Arm Assembly
14631-PR3-000 Rocker Arm Shaft
14820-P73-J01 Lost Motion Assembly
Throttle Body
16075-P07-000 Map Sensor O Ring
16176-P73-004 Throttle Body Gasket
16400-P73-A01 Throttle Body Assembly
16411-P73-000 Throttle Cable Bracket
36450-P6-S01 Idle Air Control Valve
36455-PT3-A01 Iacv O Ring
Valve Cover
12310-P73-A00 Valve Cover
12341-PR3-000 Valve Cover Gasket
12342-PG6-000 Spark Plug Grommet
90442-P73-J00 Chrome Grommet
90213-PH3-000 Chrome 10mm Nut
12500-PR3-000 Ignition Wire Cover
15610-P2E-A01 Oil Filler Cap
Engine Harness
30530-PV1-A01 Knock Sensor
31112-P2T-000 Lower Alt. Bracket
31113-P2T-000 Upper Alt. Bracket
37240-PT0-014 Oil Pressure Switch
78410-ST7-003 Speed Sensor
32110-P73-A02 Engine Wiring Harness
32610-ST7-961 Engine Ground Wire
Distributor
06302-PM6-H00 IGNITOR KIT (Non-OBD Distributor)
Clutch Assembly
22300-P73-025 Pressure Plate
22200-P73-R01 Friction Disc
22100-P73-005 Flywheel
91006-634-008 Pilot Bearing
90034-689-000 Clutch Bolt
90011-PH3-000 Flywheel Bolt
Exhaust Manifold
11942-P73-000 Exhaust Manifold Bracket
18100-P73-A00 Exhaust Manifold
18100-P73-J12 98 Spec. Type-R JDM 4-1 Header
18199-P73-J01 Jdm 4-1 2.5" O Ring
Unknown
JDM 4-1 Bracket
18120-P73-J12 Jdm 4-1 Top Heat Shield
18121-P73-J12 Jdm 4-1 Bottom Heat Shield
18115-P30-013 Exhaust Manifold Gasket
18229-SP0-J51 Exhaust Manifold Donut Gasket
18120-P73-A00 Outer Heat Shield
Intake Manifold
06164-P2J-000 Fuel Injector
16472-P0H-A01 Injector Seal Ring
16473-P10-A01 Lower Seal Ring
91301-PM7-003 Injector O Ring
16620-P72-010 Fuel Rail
16622-P73-000 Fuel Rail Stiffener
16740-P73-003 Fuel Pressure Regulator
16010-SK7-506 Fuel Filter (Da Integra)
17100-P73-A00 Intake Manifold
17100-PCT-000 Intake Manifold (Ctr)
17105-P73-A01 Intake Manifold Gasket
17132-P73-000 Intake Manifold Bracket
17130-PM6-003 Pcv Valve
Oil Pump
15100-P72-A01 Oil Pump
91308-PK1-003 Oil Pump O-Ring
91212-PR4-A01 Oil Pump Front Seal
15400-PR3-014 Oil Filter
15232-PG6-000 Relief Valve Spring
15231-PE0-000 Relief Valve
15220-P72-000 Oil Strainer
15221-PW0-S01 Oil Strainer Gasket
37500-P72-A01 Tdc Sensor
18121-P73-A00 Inner Heat Shield
Water Pump
19200-P72-013 Water Pump Assembly
19222-PR4-003 Water Pump Gasket
19505-PR3-000 Water Connecting Pipe
91314-PH7-003 Water Pipe O Ring
19320-P30-J00 Thermo Housing Inner
19311-P2T-000 Thermo Housing Outer
19301-P08-316 Thermostat
37760-P00-004 Thermoswitch
37870-PJ7-003 Coolant Temp Sensor
37750-PH2-014 Temp Sending Unit
19315-P30-J01 Upper Hose Outlet
Timing Belt?
14111-P73-J00 98 Intake Camshaft
14111-P73-J01 01 Intake Camshaft
14111-PCT-000 Ctr Intake Camshaft
14121-P73-J00 98 Exhaust Camshaft
90741-657-000 Cam Key
91213-PR3-013 Cam Gear Oil Seal
12513-P30-000 Cam Seal Bung
90031-PV0-003 Cam Gear Bolt
14211-PR3-003 Cam Gear
14510-P30-003 T-Belt Tensioner
90026-PR3-003 Tensioner Bolt
0214400-PR3-0 04 Timing Belt
14400-P72-014 Timing Belt
00231110-P01- 003 Alternator Belt
11840-P72-010 Back Upper Timing Cover
11820-P72-000 Front Upper Timing Cover
11810-P72-A00 Lower Timing Belt Cover
TypeR
Message par TypeR » lun. févr. 06, 2006 6:19 pm
18100-P73-J12 98 Spec. Type-R JDM 4-1 Header CA PESE QUAND MEME 8.33 Kg cette bete
ITR #4592
dycast
Message par dycast » lun. févr. 06, 2006 7:38 pm
TypeR a écrit :18100-P73-J12 98 Spec. Type-R JDM 4-1 Header CA PESE QUAND MEME 8.33 Kg cette bete
ça fait qu'un kilo de plus que le mugen ! pour 500€ de moins et de bonne perf
2 ou 3" mc do" de moins dans l'année et on récupere le kilo :lol: c'est du vécu :lol:
seb
Message par seb » lun. févr. 06, 2006 8:28 pm
Vive le maxi best of mugen :D
The Power Of Dreams
christophe.m
Message par christophe.m » lun. févr. 06, 2006 8:55 pm
cool la liste j espere que ta fait du copier collé :lol:
